atkAudio Plugin
atkAudio Plugin 0.32.1
I try delay on a media source, so when I move the slider it sounds like it's fast forwarding a recording, but when it gets there it continues the playback not repeat it. Is this what it's supposed to be doing? I thought delay was like singing in a stadium where you say something and you can hear it minutes later. Thanks for all your hard work and effort!
I think I see it now. LOL. I'm singing, but my mouthing of the words were behind me, correct? Thank you!
Some of your audio plugins have a white background. It might be my eyes only, but it's next to impossible to read. Is it possible to fix it? Au reverb2 for ex. Awesome plugin though! It's just some. Thanks!
So I set this plugin up an at first it seemed to be working great but ever since I set it up an added VST3 plugins. On avg every 30-40 minutes into stream obs just crashes and Im not sure why. Has anyone else had this issue. Im running a AMD Radeon RX 9070 XT Graphics card so it should be more than powerful enough to run anything. Has anyone else had this issue?
Also for reference heres my crash file.
Hi, I absolutely love this plugin. Thank You! However, after I choose some of the plugin hosts for the effects some of them have a super white background. For me this is blinding and I can't read it. It might be just my eyes, but if I'm not the only one maybe you might want to fix it? Can you or is it an apple thing? I would tell you which one as an example, but I can't read it. I don't want to do anything to lose the one I'm using because it's making my recording sound good (LOL). Thanks so much.....Yikes! I discovered this effect by accident and it's making my personal performance sound really really good. I was feeling bad about my performance until now. Just enough reverb and whatever this plugin has to offer is doing it right now. Again, thanks so much!
Maybe it's my Mac? I leave it unattended for a while and it has a readable dark background then quickly goes away. Prayerfully this will be fixed somehow. Thanks......update: Unfortunately still a white background. I can see sliders, but that's it! Thanks so much!
Can someone please help me? The issue I have is with OBS and AtkAudio DeviceIo.
- Windows 11, MOTO 828ES, Eurorack synths, poly synths, drum machines etc
- I have AtkAudio installed and active on an Audio Input Capture channel as a filter.
- I am able to record audio successfully from multiple channels and it sounds great.
- PROBLEM. Each audio channel is sequentially played back as left, right, left, right (so 1 is left, 2 is right, 3 is left etc)
- I have selected MONO in the settings but this has not helped.
- I have played with panning in my MOTU interface as well as in the Atk filter.
So how do I get control over where each signal will present in the stereo field?
try with pluginhost2. It allows much more than just hosting plugins.
Okay so I installed pluginhost2 and I can add it as a filter, but from there I am unsure what to do.
I created an AUDIO IN with 8 channels (one of my MOTU racks) to test.
I can drag and connect ins and outs but the monitoring metre remains MONO (right side).
Is there a tutorial I should view?
there is no tutorial. you can connect one pin into multiple pins, i.e. channel X to both left and right
Thanks for trying to help.
What I have is:
Audio Input Capture with plugins: (in this order)
- atkAudio PluginHost2
- atkAudio Device Io
Within PluginHost2 I have:
- audio input with the 8 motu channels ticked
- audio output with my standard monitor outs (only) selected
Synth audio is coming in on input 6 on my MOTU.
If I drag and connect a line from input 6 to one or both of the outputs a different tone occurs, almost like a filter or phase effect.
At no time does the Audio Mixer channel in OBS show audio on left and right, it is only right (and that is how it records).
What am I missing?
What I have is:
What am I missing?
dont use DeviceIo when using PluginHost2. Use only PluginHost2.
What I have is:
What am I missing?
do something like this.
So that worked great. I feel a bit emotional haha. I have been trying to get a working rig running for a long time. I fluked it with OBS a few years back but couldnt get it done after a PC rebuild.
I did the below and I can now record signals in centre of the stereo field. I guess next I will look at inserting plugins like you have done with the GAIN example above.
Thanks so much. Definitely a donate on payday this month.
