Fractal Scape headset not appearing in audio mixer in OBS
SkipRat
I have a problem in OBS regarding the Fractal Scape headset in Bazzite.
Whilst the headset up is showing up in the device list and I can play with all the settings, the headset is not showing up in OBS. Thus OBS is not recording any sounds despite, being able select the device in options.
Anyone have any ideas on how to get the the headset to show up under Audio Mixer dock in OBS?
I am currently using the latest verson of Bazzite 43, OBS installed from Flatpak in Bazaar.
You may have inadvertently duplicated the audio in your output.
When I have a global device, it can be heard globally on stream or in recording without adding it as a source.
This is made clear in newer builds of OBS (I'm using today's master branch). When I add a global audio source it appears in the mixer as "Mic/Aux".
