Multiple OBS Instances on Mac
rexeisen
I don't want to rehash all the drama in https://obsproject.com/forum/threads/bug-in-31-0-2-when-using-multiple-instance.184677 however, it seems like the suggested to running multiple instances / streams is to use Portable Mode. For reference, I run streams for a youth sporting event where we use multiple cameras/streams to allow families to watch their kids compete and perform when they might not otherwise be able to travel.
Looking at https://obsproject.com/kb/portable-mode, it doesn't seem like OBS currently supports portable mode for Mac (or Linux for that matter)
Is there any guidance on how we'd go about running multiple streams or is my use case no longer supported by OBS?
Second. Multiple instances has been a core part of my workflow since OBS was ported to apple silicon. I run a primary stream and a secondary with ASL interpretation. My current workaround is double the computers, double the capture cards, double the producing.
Thanks for your consideration
Hi everyone,
I finally found a viable option that works for the time being. Using the app Parall (paid, but works - https://parall.app/) I was able to create multiple instances of the latest OBS (32.1.1) and it doesn't hard lock on launch. I'm still going to be playing around with doing some linking of the Application Support folders to see if I can still have multiple instances run on a single configuration, but I'm no longer locked to 31.0.1.
Hi rex, very first question on this forum for me, not sure if you can answer. when I try to close out one of the mirrors of a virtual stream it won't let me, the platform shows it is 'offline' but the stream is still live, only when I shut down the main virtual feed does the mirror go offline. Another mirror has a button in the platform which stops the broadcast but the other problem mirror does not, I want to have complete independent control, any single one alone with others shut down.
