Overwrites Default Videodevice
asdjflkjasdf
Hi folks,
i'm using Iriun for my phone being a webcam device, because my laptop hasnt one. This is just functioning well, and I can use it as it is, in my coming meetings. But I wanted to put some extra info to my presentations. So I installed OBS from my repo. To get the phonecam signal via Wifi, I need to run the desktop as a server which means, I need to run Iriun and OBS together.
When I turn on the Virtual Cam Mode, I see green flickering lines overlayed by the phone-cam output in the multiview and everywhere. As I set source and destination to the same resulution and settings, I can imagine, that theres any driverbased issues with that. Does anyone have had expieriences with that?
I just would need to priorize the output from OBS somehow, because Iriun gives a default cam to my machine, which get overritten somehow from OBS.
The goal is, to use the OBS program out as the main webcam-source for my machine. And I have NO idea, to get there.
Here are two pictures of both, with virtual cam active, and turned off vc.
OBS uses the first v4l2loopback device. If that happens to be the same as iridium's you have a conflict. If iridium has no option to configure that, i think there is little you can do.
Hello, thanks for your answer, I tried to add 2 v4l2loopback-devices to my machine, but programs will use the video0 instead, both. I cannot say, you guys use this, you that. And I found out, that OBS has no program-view ouptut from virtual camera either, even if the Iriun Input is not there. Any ideas?
See, there is no warning, and nothing happens in the logfile, so I wasnt posting any of these info.
Cheers
you can see yourself:
11:02:09.051: Using EGL/X11
11:02:09.051: CPU Name: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
11:02:09.051: CPU Speed: 400.000MHz
11:02:09.051: Physical Cores: 2, Logical Cores: 4
11:02:09.051: Physical Memory: 15645MB Total, 14063MB Free
11:02:09.051: Kernel Version: Linux 6.5.0-13parrot1-amd64
11:02:09.052: Distribution: "Parrot Security" "6.0"
11:02:09.052: Session Type: x11
11:02:09.052: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
11:02:09.053: Qt Version: 5.15.8 (runtime), 5.15.8 (compiled)
11:02:09.053: Portable mode: false
11:02:09.110: OBS 29.0.2.1-1+b1 (linux)
11:02:09.110: ---------------------------------
11:02:09.240: ---------------------------------
11:02:09.240: audio settings reset:
11:02:09.240: samples per sec: 48000
11:02:09.240: speakers: 2
11:02:09.240: max buffering: 960 milliseconds
11:02:09.240: buffering type: dynamically increasing
11:02:09.284: ---------------------------------
11:02:09.284: Initializing OpenGL...
11:02:09.317: Loading up OpenGL on adapter Intel Mesa Intel(R) HD Graphics 620 (KBL GT2)
11:02:09.317: OpenGL loaded successfully, version 4.6 (Core Profile) Mesa 22.3.6, shading language 4.60
11:02:10.253: ---------------------------------
11:02:10.254: video settings reset:
11:02:10.254: base resolution: 1920x1080
11:02:10.254: output resolution: 1920x1080
11:02:10.254: downscale filter: Bicubic
11:02:10.254: fps: 30/1
11:02:10.254: format: NV12
11:02:10.254: YUV mode: Rec. 709/Partial
11:02:10.254: NV12 texture support not available
11:02:10.254: P010 texture support not available
11:02:10.263: Audio monitoring device:
11:02:10.263: name: Standard
11:02:10.263: id: default
11:02:10.263: ---------------------------------
11:02:10.282: Failed to load 'en-US' text for module: 'decklink-captions.so'
11:02:10.286: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
11:02:10.300: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
11:02:10.300: Failed to initialize module 'decklink.so'
11:02:10.576: [pipewire] No captures available
11:02:12.199: VAAPI: API version 1.17
11:02:12.200: FFmpeg VAAPI H264 encoding supported
11:02:12.451: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.1.0 | RPC Version: 1)
11:02:12.451: [obs-websocket] [obs_module_load] Qt version (compile-time): 5.15.8 | Qt version (run-time): 5.15.8
11:02:12.451: [obs-websocket] [obs_module_load] Linked ASIO Version: 102201
11:02:12.471: [obs-websocket] [obs_module_load] Module loaded.
11:02:12.643: [vlc-video]: VLC 3.0.20 Vetinari found, VLC video source enabled
11:02:12.643: ---------------------------------
11:02:12.643: Loaded Modules:
11:02:12.643: vlc-video.so
11:02:12.643: text-freetype2.so
11:02:12.643: rtmp-services.so
11:02:12.643: obs-x264.so
11:02:12.643: obs-websocket.so
11:02:12.643: obs-transitions.so
11:02:12.644: obs-outputs.so
11:02:12.644: obs-filters.so
11:02:12.644: obs-ffmpeg.so
11:02:12.644: linux-v4l2.so
11:02:12.644: linux-pulseaudio.so
11:02:12.644: linux-pipewire.so
11:02:12.644: linux-jack.so
11:02:12.644: linux-capture.so
11:02:12.644: linux-alsa.so
11:02:12.644: image-source.so
11:02:12.644: frontend-tools.so
11:02:12.644: decklink-output-ui.so
11:02:12.644: decklink-captions.so
11:02:12.644: ---------------------------------
11:02:12.646: ==== Startup complete ===============================================
11:02:12.804: All scene data cleared
11:02:12.804: ------------------------------------------------
11:02:12.825: pulse-input: Server name: 'PulseAudio (on PipeWire 0.3.65) 15.0.0'
11:02:12.826: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
11:02:12.827: pulse-input: Started recording from 'alsa_output.pci-0000_00_1f.3.analog-stereo.monitor' (default)
11:02:12.827: [Loaded global audio device]: 'Desktop-Audio'
11:02:12.830: pulse-input: Server name: 'PulseAudio (on PipeWire 0.3.65) 15.0.0'
11:02:12.831: pulse-input: Audio format: s32le, 48000 Hz, 2 channels
11:02:12.833: pulse-input: Started recording from 'alsa_input.pci-0000_00_1f.3.analog-stereo' (default)
11:02:12.833: [Loaded global audio device]: 'Mikrofon-/AUX-Audio'
11:02:12.839: [window-capture: 'Gegenseite'] update settings:
11:02:12.839: title: unknown
11:02:12.839: class: unknown
11:02:12.839:
11:02:12.843: xshm-input: Geometry 1920x1080 @ 0,0
11:02:12.853: [window-capture: 'Sozi Präsi Ausbildung'] update settings:
11:02:12.853: title: unknown
11:02:12.853: class: unknown
11:02:12.853:
11:02:12.855: xshm-input: Geometry 1920x1080 @ 0,0
11:02:12.861: v4l2-input: Start capture from /dev/video0
11:02:12.871: v4l2-input: Unable to set input 0
11:02:12.871: v4l2-input: Initialization failed, errno: Unpassender IOCTL (I/O-Control) für das Gerät
11:02:12.872: [window-capture: 'Iriun Stream Fenster'] update settings:
11:02:12.872: title: unknown
11:02:12.872: class: unknown
11:02:12.872:
12:05:56.726: [window-capture: 'PIP Webcam'] update settings:
12:05:56.726: title: Iriun Webcam for Linux v2.8.2
12:05:56.726: class: iriunwebcam
12:05:56.726:
12:07:05.399: Last log entry repeated for 229 more lines
12:07:05.399: X Error: BadWindow (invalid Window parameter), Major opcode: BadValue (integer parameter out of range for operation), Minor opcode: 0, Serial: 347025
Ok, after a bit deeper diving in this, Im able to manage my v4l2-ctl settings now, and modprobe new devices, step by step learning linux and cli. But I can never change any hardcoded settings, either from the newer versions of OBS, nor the iriunwebcam. Both programs outputs their video to the same card (same v42lloopback device). And I couldn't find any options to choose between v4l2-input or -output. So, I need another way, to integrate v4l2-inputs to OBS on my debian machine.
Does anybody know such software, that let me change things like I/O generally, flexibly? :)
