Text - Drop Shadow gone?
Don't know what the history on the text source's drop shadow option is, but you could consider using the obs-shaderfilter plugin in the meantime; it includes an example shader for applying a basic drop shadow to any source, including text.
Drop shadow still works just fine in the FreeType 2 text source. On Windows, you can find it under the "Deprecated" submenu when adding a source. If you absolutely need drop shadow on text on Windows, you can use that, or try the shaderfilter plugin mentioned above.
problem with this is that it's not using "custom" fonts
Well I don't know what are they on version 33, You would think you would be able to add a shadow to a font by now That's nuts
Hi, I installed the latest version and I noticed that when recording from the Dynacord 1600-3 via a 3.5mm audio cable to the computer, the recording has a rhythmic, light and constant click that the previous version did not have. I don't know what to do about it, the AIs give me answers that don't help me. Please give me a suggestion on what to try to do.
