Using Everast Cast to stream live on TikTok (using OBS)
newhereneedhelp
Hello:
First time using OBS.
I am trying out a service called Everast Cast.
It allows you to upload music to a server and by creating playlists it will play songs one after the other automatically.
Is an autoDJ feature.
It works through Shoutcast servers.
If anyone is familiar with such, do you know if is possible to set up OBS to be able to stream the music live on TikTok?
If so, how?
Within the settings of Everarst, there is not a setting for TikTok specifically, so if is possible must be another way (a work around) to do this.
I contacted support to help me but was told they can't since this is a 3rd party thing.
Thanks.
This discussion about OBS Studio and TikTok is really helpful. When using Everast Cast, it is important to configure the correct RTMP URL and Stream Key. If you don't get direct support, you can use Live Studio or a third-party service. Also, the tiktok emojis trend often helps to increase engagement.
Thanks for replying. How do I get the stream key for TikTok?
What is the TikTok emojis trend?
TikTok do not support using 3rd party applications to stream unless you have a special arrangement with them.
