WoLNamesBlackedOut for OBS
WoLNamesBlackedOut for OBS v1.0.5
Calocen Rieti
Calocen Rieti submitted a new resource:
WoLNamesBlackedOut for OBS - This is a filter plugin that blacks out character names on the FF14 screen when streaming via OBS.
This plugin hides character names from the FF14 screen when streaming (capturing) with OBS.
This is an OBS plugin port of the Windows application "WoLNamesBlackedOut".
It detects and filters usernames using DirectML.
The original is here:
https://github.com/royshil/obs-detect
This fork adds the YOLODetector class and supports custom YOLO26 models.
It also improves FPS by threading inference.
Changes from the Original...
Calocen Rieti updated WoLNamesBlackedOut for OBS with a new update entry:
We've added the ability to set areas to exclude from masking.
If you want to mask other characters but not your own, you can set the exclusion range to only the area around your character's name using "Exclude Options". This will exclude the area around your character's name from masking.
If the name detection area overlaps even slightly with the mask target area, it will be masked.
While this is a simple implementation, it was chosen because implementing countermeasures using detection methods is difficult due to processing speed and other factors.
