Audio Waves Visualizer Plugin
Audio Waves Visualizer Plugin 3.0.5
MMLTech
Member
MMLTech submitted a new resource:
Audio Waves Plugin – Create Visual Waves From Any Audio Source - Generates a visual audio-wave source from any input and lets you position it freely.
Audio Wave Visualizer for OBS Studio
Documentation & Install: https://mmltools.github.io/audio-wave
Download latest: https://github.com/mmlTools/audio-wave/releases
If you find this script useful and wish to support further development:
Ko-fi: https://ko-fi.com/mmltech
PayPal: https://paypal.me/mmltools
This plugin adds a new source type to OBS Studio...
MMLTech updated Audio Waves Plugin - Create Visual Waves From Any Audio Source with a new update entry:
Added a new option Rectangular Waves
- The new option allows you to create a beautiful profile overlay along with the mask filter, plug it to your mic/aux source and give your stream a pint of style.
!ATTENTION! This option may be very resource consuming so a powerfull GPU is a must have for the full potential of this plugin !
Hello.
I wanted to test your new work, but I don't see anything at all: needed source does not appear among the sources, your plugin does not appear even in the Plugin Manager.
I use Windows 10, OBS 32.0.2, I set the folder from your archive to the appropriate "64bit".
Are you sure you have the right file configuration and installation instructions?
Hello.
Can you send me the curent log? The auto build from github may be messed up, I’ll have a check.
Hello.
I see where the problem is, github wraps the files inside bin/64bit and you have to put the dll in obs-studio/obs-plugins/64bit I'll fix the pathing in the next release
Yes, if you transfer .dll and .pdb directly to "64bit" (how this is done for other plugins), then everything is ok.
Hello.
I would like to draw your attention to the fact that all your distributions in all versions have the same numbering: 1.0.0.
@MMLTech
Question:
I was able to install the plugin successfully, but the “Color 2” option does not appear in the properties window.
Are there any prerequisites or required settings for this option to be displayed?
Or is it possible that I am using a different version than the one shown in the samples?
Here are the steps I followed:
I downloaded audio-wave-1.1.2-windows-x64.zip from “Download latest,” extracted the files, and placed audio-wave.dll and audio-wave.pdb into:
C:\Program Files\obs-studio\obs-plugins\64bit
Please note: I'm writing this through translation, so I apologize if anything sounds unclear or incorrect.
Gradient option was removed in v1.1.1 because it was causing too much lag
Being able to generate clean audio wave visuals from any source is great for podcasts and music streams. The flexibility in positioning makes it easy to fit into different layouts without much effort. Looking forward to trying this version out.
The whole plugin is basically plug an play, generates a video source that makes everything very easy to work with. And you can combine multiple sources to build a nice overlay, everything optimized to save resources.
